another newbie fuel controller question
I bet I could cut and paste this question from a hundred different post but here goes anyway. I've got an 08 ultra with ABS and drive by wire throttle. I plan on adding Rush slip-ons and probably a different AC. I don't hot rod but I do love to tinker and experiment with different set-ups. I tried the SERT on my 07 and my dealer lacked the abbility to tune it correctly so I ended up with a popping, pinging 25MPG bike that was barley rideable until I installed a canned map.
Two questions:
1. Can I add the Rush mufflers with 1.75" baffles and leave the stock AC and not change the fuel just to get me through the winter until I can save up some cash?
2. In the spring, which controller should I go with. The Tmax or the DTT. Any info on Pro Cons of both units would be appreciated.
Two questions:
RE: another newbie fuel controller question
ORIGINAL: drichards
Two questions:
Two questions:
Answer to #1: Yes you can. Change either end (intake or exhaust), but not both without changing air/fuel getting to the motor.
Opinion to Question #2: ThunderMax w/AutoTune & the wide band O2 sensors is probably as good as it can get. Also, it isthe top of the price chain. There are numerous choices from there that start getting a lot cheaper.
I am saving for a T-Max, but currently running my stage 1 mods with a V&H FuelPak. Is it perfect, no. Does my bike run better & cooler? Yes.
Personally, I'd go with just changing out the mufflers in a heartbeat, but wouldn't change the airbox under any circumstances without addressing the changed VEs that would result, even if the airbox was the only breathing change I made.
Between the TMAX and DTT, from what I've been able to glean from their published and available-on-the-Web information, I think the DTT would be my direction. But that's a safe thing to say at this time since neither is really on my radar just yet.
If I had an '08 and had to have one or the other, though, the first one to get one available to me would suffice. They both have a pretty good track record so far from what I've seen.
I use the SERT on my 08 Ultra because I didn`t care to wait for the release of the DTT system. The SERT will give you all the tuning you`ll need. The only drawback is it marries to the ECM for life. It can only be used on the first ECM it mates with.
I have the DTT/WEGO IID on my 07 FLHX. IMO it`s the best box.
Respectfully, that was a true statement until you got to the ",,,,," part and what follows.
I've logged somewhere between 1 and 2 thousand miles with just 2" Rushes, everything else stock. It works and works extremely well. I don't know if I'd recommend larger baffles than that, but 2" definitely work well with the ECU and friends.
I don't believe they have the TMax out for the 08 models yet. If I had to do it all over again, I would have went straight to the TMax. You will have to check to see what is available for the 08 on the tuners as the drive by wire may preclude some of them from working.
