SERT--DOES work with Vista!
I didn't tryto connectbefore-hand to see if I had a problem, but go into your Program Compatibility Wizard, use either the find programor manual search to find the Tuning Mode and Data Mode (you'll have to do them 1 at a time), click Next, and then select XP to make them compatible, and go through the rest of the steps.
I don't know if it also helped, but I connected everything, then turned on the laptop, and then ran Tuning Mode, then went through the Program ECM steps to get ECM info and to program the ECM. I din't have a single hiccup with any of this.
Also, since my laptop doesn't have a serial port, I had already installed a USB-Serial adapter and selected the appropriate COM port in the SERT program.
ORIGINAL: UltraKla$$ic
So you were able to actually program your ECM using Vista? Not look at the ECM info using Vista, but actually program the ECM...ie reflash/flash? Correct?
ORIGINAL: Wide06
Yup. I even disconnected and reconnected to verify the new calibration was on there. I'm going to wirk with Data Mode this weekend.
Islander
11-07-2006 01:49 AM
