adjusting the idle?
adjusting the idle?
I have a 2007 Streetbob. My last bike was a 97 sporty 1200. I'm new to the whole EFI stuff. Is there any way to adjust the idle? The new EFI motor idles just a little to fast for my likeing. Any help would be greatly appreciated. By the way, no mods, just a stock bike.
RE: adjusting the idle?
I think that injected models idle is always faster than carburated ones, so that if you had an sporty before, I think you won't be able to have the potato potato sound you had with this one. In other way, I suppose that the idle could be lowed a bit, but as my bike is carburated, really don't know how to do this.
Good luck,
Javi
Good luck,
Javi
The dealer can lower it a bit with the digital tech but don't try to adjust the set screw in the throttle body. It's sealed to begin with for a good reason. It will throw off the TPS settings and that will effect the enitre system. The higher idle will keep the battery up with the addition of the electric fuel pump used and the other sensors not needed in the carbed bikes.
I agree. I set mine at 848 rpm with a sert. Perfect.
ORIGINAL: Jaybob07
donny66
Milwaukee Eight (M8)
06-05-2019 08:52 PM
