Thundermax the best?
Old 10-20-2007, 12:18 PM
jbochnia's Avatar
jbochnia
jbochnia is offline
Stage IV
Default RE: Thundermax the best?
I just purchasd the Zippers Nitrous Oxide dry system for HD. It is to be used as aclosed system o my soft tail. Does anyone have it? How do you like it?
Old 10-22-2007, 11:15 AM
drichards's Avatar
drichards
drichards is offline
I noticed you seem to know something about these "auto tune" controllers. I've got an 08 ultra that I'm not going to be able to leave alone no matter how hard I try. I tried the SERT on my 07 but my dealer never could get the tune right and It's a long ride to the next one. Which of the wide band systems do you recomend for a small mods (slip ons or pipes later, AC) so I don't have to pay a dyno fee every time I change something?
Old 10-25-2007, 05:14 AM
silvrbill's Avatar
silvrbill
silvrbill is offline
I installed the TMAT on my 08 FXSTC when it had about 100 miles on it. Did the breakin, had my service and went to Colorado for a week. Climbed Pikes Peak without any problems(over 14,000 feet), the bike ran real good and got good gas mileage too. Haven't even tweaked on it yet so I imagine there is more I can get from it as far as power and mileage. All in all i'm completely satisfied with it so far.
Old 10-25-2007, 11:47 AM
ToBeFrank's Avatar
ToBeFrank
ToBeFrank is offline
ORIGINAL: drichards
It depends on what you're looking for. The DTT is harder to setup and somewhat more difficult to understand. Having said that, the DTT is an "open" system. You can see and change just about everything about it. The TMAX, on the other hand, is about as simple as it gets to setup and is fairly easy to understand. However, it is more of a "closed" system. They only give you access to the tuning parameters they think you should see, which doesn't include the offsets the ECM is learning based off the oxygen sensors. Also, the DTT uses MAP for timing whereas the TMAX uses TPS for timing (advantage DTT in my opinion).
I have the TMAX, but I would be very unhappy with it if I didn't have access to their "advanced" software. If the DTT were easier to install, I would have gone with it instead. Like I said, it's all in what you're looking for.
Old 10-25-2007, 02:38 PM
glens's Avatar
glens
glens is offline
That comparison can be almost used word-for-word between GNU/Linux (=DTT) and MS Windows (=TMAX). I've been using Linux exclusively for my private computing for more than a decade. Every time, without fail, when I sit down in front of a Windows screen it seems as though I've been fitted with handcuffs that have no interconnecting chain. This is why when the time comes to make the change, I'm going to go with the DTT product. I really like their engineering style.
Old 10-25-2007, 03:05 PM
ronyd's Avatar
ronyd
ronyd is offline
Wow glens, blending software OS with Tuners. I know what you mean for the analogy (since I'm a software engineer).Really not intimidated at all with any of the fuel management systems as far as use, just what number to put in. I know how to build kernels, but can I mastertuning my bike is the question??? Only time and $$$ I spend to find out will tell...
greybeard122
03-25-2012 10:15 PM
jankovic
05-04-2011 12:40 AM
roadking1893
10-21-2010 06:10 AM
rbabos
06-14-2007 05:57 PM
Road King Ron
02-23-2007 02:16 AM
Quick Reply: Thundermax the best?
