TC88b custom spark issue
Old 10-05-2007 | 12:17 AM
flattrack57's Avatar
flattrack57
Stage III
Default TC88b custom spark issue
hi - hope someone can help me!
I built a Yaffe framed, TC88B Harley motor custom (new 2005 carb motor). Its put together and it is all ready to go. All electrics work but it won't spark/start. Horn, lights, turn signals, brake lights. starter motor all work. I have a new Screamin Eagle ignition module for an '05 carb model. The coil is a working (supposedly) take off coil. I do NOT have a bank angle sensor. The SE ign module for an '05 has one, 12 pin connector. I used 11 of them; all except the "serial" input from the Turn Signal Module (which apparently houses the Bank angle sensor).
Question is; do I NEED a bank angle sensor input for the motor to spark?
Any suggestions on what to check first?
The motor is new. The crank position sensor is new and came with the motor.
Any help appreciated!
Maury
crestwood
Electrical/Lighting/Alarm
14
05-27-2024 03:48 PM
Donald Lowndes
02-20-2020 03:57 PM
divco13
13
02-08-2019 08:37 PM
Tripdad+1
08-23-2017 06:58 PM
flattrack57
Exhaust System Topics
10-05-2007 09:05 PM
Quick Reply: TC88b custom spark issue
