Sputtering, spitting, dying....please help
I have a 1986 Heritage. I purchased used in 05. Ever since, I have consistantly had electricial troubles. Mainly with buring up plugs. Currently, the bike will start but sputters and barks and if try to ride, it dies. I have installed a new ignition switch, coil, and plugs but to no avail. Any suggestions?
RE: Sputtering, spitting, dying....please help
Have you taken it to a HARLEY Tech.? Or a at least a no name shop that works on HARLEYS? It sounds like trash in your Carb. or float sticking, has it been sitting up and not been rode for a while? It could be bad gas or try new set of plugs and wires (cheap $12.00 plug wires, $15.00 Trip. Plat. plugs) and empty out old gas and put fresh high octane in it, thats as far as I could get for you, have you made sure battery is good and tight? GOOD LUCK! LET ME KNOW WHAT YOU FIND! PURPLE HAZE.
[IMG]local://upfiles/24725/59272DE2C8884D66A58E8007F7FA5325.jpg[/IMG]
[IMG]local://upfiles/24725/709A1E7AC2E04A188B916D49908F0E2D.jpg[/IMG]
hanoverdigger
08-24-2017 02:31 PM
