07 Airfilter back plate wiring
Hello,
I have installed a K&N stage 1 high flow filter to my Road King Classic 07. Iremoved the original back plate and disconnected the wiring towhat looks to bea choke flap.WhenI installed the K&N back plate there was no harness for the original wiring to attach to, nowI have a constant engine warning light on my panel. Im assuming its the open wiring thats not reconnected.
Can anyone advise whats ment to happen with the un used wiring and the enginewarning light ?
Thanks.
Spot.
Thanks.
Spot.
RE: 07 Airfilter back plate wiring
The wire intermittently sends a signal to a solenoid which activates a flap in the international version airbox. When you take away the load (the coil in the solenoid) its absence is noted by the engine's computer, hence the code/light. You have to provide a suitable load to the connector. I've seen (somewhere) "dummy" plugs you can attach to the connector to satisfy the computer. You could also remove the solenoid from the stock airbox and connect it, stowing it neatly away somewhere.
Spot, don't know if you can get Zodiac stuff, but they have a plug in bypass device for the active intake solenoid. It's just a resistor of the same resistance as the solenoid coil packaged so you canplug it in. There was a guy on this forum that was selling a similar product, but can't remember who it was. Maybe a search for active intake bypass or eliminator would turn him up.
http://www.harley-mania.co.uk/produc...oducts_id=1314
xracer110
Electrical/Lighting/Alarm
12-02-2012 07:15 AM
