Tmax vs. Twin Tech vs S&S VFI vs PCIII
RE: Tmax vs. Twin Tech vs S&S VFI vs PCIII
I've done alot of research on this and it comes down to $$$ you want to spend. Tmax/Autotune wins hands down, with all the threads about it, all are good and no complaints (see alsoat *****************). On the low end $$$, PCIII seams to be a favorite. but with its querks.
I would read the crap out of these threads. Alot of good info...
I was in the same boat as you, I spent 8 month agonizing over what to buy, (hate wasting money,) after all the crap I read about PClll frying ecm's serts needing expert tuners hours of dyno time $$$, pulse extenders (serf,tfi and such) tmax $$$$. After reading everything I could find by shovelhead bob and one screaming eagle, I was convinced if I bought the right combo of a/c and pipes, the sert with the canned map for 07 w/02 stage 1 and a good set of slip ons would put a smile on my face. Am I smiling?
I did the same thing try them all and they all work, the sert was cool but the ecm is very temperamental many of times I would get these wired faults that would stop the process right in the middle of my download to the ecm. Most of the time I could reload the map and it would be fine. You notice I said MOST[/b] of the time one time my computer died when I was downloading in to the ecm, 3 weeks later I was back on the road. PC III was cool it was very easy to use and work great other than my bike ping when I use it I went through two of them. Put a Tmax in last night man am I impress no pinging and a little popping (very little) and runs much smoother. But I do not want to get my hopes up, let me put a couple of hundreds of miles on it and I will get back on how the Tmax work and how my bike ran. Give me about 3-4 days.
Do a search for "DTT" and you will find a lot of info on this forum and quite a few guys running them, particularly on bikes that have built engines, but some running on stockers too with great results. Either T-Max or DTT, price is similar, DTT is much more tuneable, but T-Max seems to get good results also.
I am running the DTT TCFI II and have had great results, and no problems.
Josey Wales
10-05-2006 09:20 PM
