Latest SERT software version?
What's the latest SERT SW version? I bought a SERT last year just after purchasing my '07 FLTR. I believe that it's version "G" but not sure as I'm not at home to check it. At the time I used a canned map for SE air intake, SE slip-on's thatIinstalled. Made a noticeable improvement but wasstill plagued by high heat issues.
Yesterday, I installed Samsom true duals and re-flashed using the same canned map but modified the 02 bias / switching voltage to .700 across the board. I guess I could have maxed them out but decided to leave a little headroom for closed loop correction. BTW, runs great and engine runs much cooler!!!
Anybody have the latest version SERT SW that might consider sending me the canned map for '07 Touring? I'd like to use it as an updated base for future corrections.
'07 Touring, 25 degree injectors, 96" with SE intake, SE Slip-on's, Samson true dual exhaust
Thanks!
Frank
Thanks!
Frank
