2015 Street Glide Can't Clear TPS Codes
Hello fellow enthusiasts. I need help with a 2015 Street Glide, 15k miles, all stock. Out of the blue with no prior work done to the bike, the check engine light came on at startup. I made it back home 50 miles on 80% power. The throttle functioned normally and it idled fine, but there was no cruise control. It has the following codes that will not clear. I’ve tried a number of ECM reset routines such as cycling the ignition 3 and 5 times.
p0120 Throttle Position Sensor 1 (TPS1)
p0123 TPS2 High/Open
p1510 EFI Limited Performance Mode
p2135 TPS Correlation Error
p2176 EFI Closed Position Not Learned
I replaced the wiring harness after the twist grip sensor thinking it might be pinched, cleaned and greased the connectors including the one at the fuel induction module. Put everything back together and still couldn’t clear the codes. Test drove the bike and the fuel gauge dropped to empty and the boom box shut off.
I checked the battery voltage at rest, the main ground, and replaced the voltage regulator. Still couldn’t clear the codes. Test drove the bike and the fuel gauge worked but the boom box was intermittent. The volt meter fluctuated pretty wildly between 14-16V while riding.
I’m not sure where to go next. I’m leaning towards the fuel induction module or twist grip sensor, but the gauge and boom box malfunctions make me think it could be something else.
https://www.roadglide.org/threads/tb...st-read.15727/
WhiskeyNWheels
03-19-2024 01:55 PM
