Twin Tec 1005 Ignition and Tuning Issues
I have a 98’ road king with a new twin tec 1005 I replace an ultima ignition with. Now that it’s installed I’m using 3 and 7 for settings and 5800 rpm
i have a Mikuni Hsr 45 for carb and not sure if I will need to retune everything because hit tuned now but with some odd noises that don’t sound to good. Will have to retune the can to this ignition. And are my setting on the modul ok. My motor is not stock list below described below
bored 10 over
.030 headgasket
cam ev 46
9:5:1 pistons
new lift valve spring
Heads ported and polished
mukuni has 45 carb
new lifters
new pushrods adjustable s&s
New bearing on cam
crank bearing new
bored 10 over
.030 headgasket
cam ev 46
9:5:1 pistons
mukuni has 45 carb
new lifters
New bearing on cam
crank bearing new
swampking
02-02-2011 06:32 AM
