SOS!!!! 2008 rocker ignition coil and hi all!
read above quotes on how I determined that. I only assume the Harley Davidson parts specialist looked up my bike which has a different wiring diagram to the other softails in twin cam.
I’m happy to be proven wrong I can work a diagram out but **** we will be here a long time….
We are straying from how I am measuring this to make sure it is faulty I really couldn’t give a f*#k if it’s what it is. I just need to know if I need another one of them to solve the issue I currently have. Please just tell me how to measure I don’t care what it is 🤣 so I don’t put money into something that doesn’t need replacing…
Also do as max says and install plugs ( so the ecm can sense compression) and crank the engine and check for sparks with two other plugs attached while resting on the engine for a ground. If you see strong sparks, your coil is good.
ResidentPirate
10-25-2012 09:07 PM
