2011 Fatbob - No spark on front cylinder
Old 08-22-2024, 08:57 PM
paulmedford's Avatar
paulmedford
paulmedford is offline
trace the blue with orange wire make sure there is 12V on it and that it has continuity to the ecm from the coil
Old 08-23-2024, 03:26 AM
Haydo4's Avatar
Haydo4
Haydo4 is offline
Paulmedford, I think it’s the ecm too.
when should that wire have voltage on it?
Only when it’s cranking?
How much voltage do I expect? 12v?
Old 08-23-2024, 03:44 AM
paulmedford
it should have 12V when cranking then drop way below12 as the the ecm grounds it to spark
Old 08-23-2024, 03:45 AM
paulmedford
but you must check continuity from the coil to the ecm. Sometimes the wire breaks and the ecm can't fire that coil
Old 08-23-2024, 12:26 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
are you getting the trigger signal from the ecm to the coil? it is a ground,,,,the ecm grounds the coil and it fires,,,,,,look up how to do that test with a 12 volt test light.
m
Old 08-25-2024, 07:19 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,954 Likes on 4,032 Posts
Ohm the coil.. Primary should be about 0.5 ohms. Primary might be shorted. If you messed with the coil, check the pins.
Old 08-25-2024, 07:22 AM
Max Headflow
Originally Posted by Haydo4
I have run test 1 with multimeter and I got 1.5v for that but can’t find a short in the wire. I have even run a loop wire from ecu to the coil with no change.
What is odd though is that I ran the same test for the rear cylinder and I get 5v.
Set to AC? Should be 12V DC most of the time as stated above.
Add:
Motor has to be running or it's only on for a few seconds at key / srun-stop switch on. While fuel pump running.
paulmedford (08-25-2024)
Old 08-26-2024, 04:07 AM
Haydo4's Avatar
Haydo4
Haydo4 is offline
Can you be specific in how to do that please
Old 08-26-2024, 05:05 AM
Haydo4's Avatar
Haydo4
Haydo4 is offline
m
I can’t find anything on how to test this.
I’m getting a bit confused atm.
With the ignition on, the blue with orange wire (front cylinder) and the yellow with blue wire (rear cylinder) are both earthed while testing with test light. (Clamp is on positive battery terminal)
While running if I probe the rear cylinder wire it will kill the engine, if I probe the front cylinder wire nothing changes, but that cylinder isn’t running in the first place. This is with the test light clamp on positive terminal.
While running if I probe those same 2 wires with the clamp on negative battery terminal I get a positive light on the test light.
Old 08-26-2024, 05:24 AM
Haydo4's Avatar
Haydo4
Haydo4 is offline
It has 12v on it as soon as ignition and run switch are on until the fuel pump stops. Then has 12v again while cranking and then running.
The rear cylinder wire does the same, the only difference between the 2 is that the rear cylinder shows a shakey light on the test light globe where as the front cylinder wire shows solid light on the globe.
Quick Reply: 2011 Fatbob - No spark on front cylinder
