Ignition Key Knob Install trouble
RE: Ignition Key **** Install trouble
ORIGINAL: rocdoc
Took the ignition key **** off easily on mu '07 FLHX now I can't get the devil back on.
Tried following the manual and it says I may need to purchase an additional tool from HD.
Any tips or tricks to putting her back on?
This may sound confusing, but it's the only way I can describe it. Basically, look at the rod, then look down the slot--and figure out how to move the two keys in the slot for the rod to fit properly. You'll know it's there when it works properly. Don't forget to use the spacers in the proper order and position, as you probably are in this fix because you inserted the rod without the spacers installed, then turned the ignition switch. As me how I know.
