Wet Bike wont start!
Hello! I have a serious problem here. Everytime I wash the bike it won't start. It's like the ignition has gotten wet. Last Biketober Fest found a wee bit of rain. Bike started acting up again like it does when washed. Took it for it's 10,000 mile check up. Ask mechanic about problem? They couldnt find. Has anybody had this happen? It's a 2003 Screaming Eagle Duece Thanks Mike
RE: Wet Bike wont start!
Could be spark plug wires, and the change out is fairly cheap and easy. Have you tried pouring water on the just the wires and plugs to see if that causes the same problem?
I have the K&N air filter inside of an S&S slotted air box and when it rains and it goes through the filter the motor gets testy... A friend has a Fatboy with a Hypercharger and it will die if it is raining very hard and gets sucked into the carb....
havent tried actually spraying the plug wires. it's done this the last couple years. the first time it's ever started breaking during a ride when it started rainning. I hate to spray it right now .. I just spent a few hours yesterday washing. it's like after a few hours of sitting there drying out.. not starting.. then it will pop off a few times ... but just one of the cylinders will fire... then after few mins the other will pop off running .. then breaks up for a few mins...it's nasty
BKSinAZ
11-26-2012 08:52 AM
