Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Was riding my 2016 Dyna Street Bob when it decided to shut off. Speedo did a reset sweep and was not able to continue throttle. I pulled over and ran diagnostic code check. Found the following codes in these modules. ECM - P1632 , BCM - B1101, B1151, B2124, U0100, SPEEDO - B1210. The bike will start and idle for a while then shut off, once in motion it doesn't stay on long. I am having trouble locating the BAS sensor so I can test voltages or attempt to bypass it. Any help would be greatly appreciated.
You may be having intermittent electrical issues. Before you start chasing codes, check both ends of both battery cables. If they are not tight and clean, then do that first. It would also be a good time to have the battery load tested.
