Testing for Spark on M8 touring
Old 01-12-2024, 10:10 PM
EZ_Glide's Avatar
EZ_Glide
EZ_Glide is offline
@WONKEY split crank case, replaced flywheel with s&s, complete cam chest rebuild with all s&s, valve spring kit s&s, new primary, new swingarm, so I really disassembled it all and rebuilt with mostly s&s parts other than trans. Now having electrical gremlins.... Will go out and check voltages from fuses in AM and see if I can get anything to power on. Was going to check compression on each cylinder to make sure that wasn't the issue and couldn't get the bike to power on
Old 01-13-2024, 04:29 AM
paulmedford's Avatar
paulmedford
paulmedford is offline
also ensure the BCM in in correctly and bolted down in the correct orientation
Old 01-13-2024, 04:44 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 5,001 Likes on 4,192 Posts
Originally Posted by Chasingdrakes
The flywheel slows down under compression. Slight as it is the ecm senses this slow down and fires the plugs.
Where did you read that from? Does the M8 have ion sense spark detector for ping detection built into the coil?
I thought Dan above was implying that. Think it uses that to know to not fire the plug.
Ion current sensing is an established method for the analysis of engine combustion. It is based on the measurement of thermally induced electrical conductivity in the combustion chamber and is used for detection of misfire, engine knocking, the air-fuel-ratio or peak pressure position.
Old 01-13-2024, 05:58 AM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is offline
Received 3,149 Likes on 1,857 Posts
Exclamation
Originally Posted by Jackie Paper;[url=tel:21524183
21524183]Where did you read that from? Does the M8 have ion sense spark detector for ping detection built into the coil?
OP, what plugs do you have installed? If not OEM, try OEM.
Old 01-13-2024, 06:28 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 9,425 Likes on 5,020 Posts
The flywheels slow down during compression, that is how the computer knows if there is compression.
The M8 does not have ion sensing, it has knock detectors.
Old 01-13-2024, 08:34 AM
Jackie Paper
Item 11 in a M8.
Dan, how does a TC know not to fire plugs? The same as a M8 or the ION sense.
Says in diagnostic manual it won't fire with plugs removed but not why.
Old 01-13-2024, 09:04 AM
EZ_Glide's Avatar
EZ_Glide
EZ_Glide is offline
Hey all, going to check fuses with multimeter in a bit, test for 12v at main 50amp fuse and 7.5 I think @paulmedford said. I looked at ground connentions by battery and those were secure. Going to try 2nd battery as well. If I can get bike powered on, going to check compression in cylinders 1st as thats needed to get it to fire (this shouldn't be issue but going to check anyways) then check 12v coming from ignition coil connection with everything connected. If bike is still not powering on will just try looking at all wires again.... plugs shouldnt be the issue I can't even get the inline spark tester to show anything on any plug so no signal is being sent to fire?
Old 01-13-2024, 09:28 AM
paulmedford
remember to check that the BCM in installed correctly as well
Old 01-13-2024, 09:29 AM
paulmedford
Item 11 in a M8.
this is the twincam manual?
Old 01-13-2024, 09:56 AM
Jackie Paper
Item 11 in a M8.
Yes, TC. I just was asking Dan hoping to clear up why the TC would not fire with plugs out for my reference notes.
People are always asking about that on. This is the first time I have seen this ask about a M8.
Quick Reply: Testing for Spark on M8 touring
