Testing for Spark on M8 touring
Old 01-12-2024, 04:21 PM
EZ_Glide's Avatar
EZ_Glide
EZ_Glide is offline
Am going to check compression on both cylinders in a bit, if that checks out I am going to then test for 12v at the ignition coil. Also need to try cranking engine longer than 5 seconds to see if there's any codes I think I am only doing it for 4 or 5 max. Ready somewhere in service manual that it takes 5 seconds for crank sensor code to pop up. Will let you all know what I find
Old 01-12-2024, 04:25 PM
paulmedford's Avatar
paulmedford
paulmedford is offline
im not sure how the M8 knows compression on cranking though, looking through the wiring diagram im not seeing how it can determine cylinder pressure as im not seeing a pressure sensor on the head. Anyway check that primary voltage because the same signal that controls the injectors controls the ignition to a large extent ( not totally) but in terms of firing.
Old 01-12-2024, 05:33 PM
EZ_Glide's Avatar
EZ_Glide
EZ_Glide is offline
Situation went from bad to worse, I just reattached battery after messing with it previously and pulling ACRs, connection to ignition coil, removed spark plugs, pulled the 7.5amp fuses to inspect then replaced and now bike doesn't get any power. Battery has 12.9v. Is best bet to try new fuses? I just visually inspected fuses but now nothing is powering on like before.
Old 01-12-2024, 05:38 PM
paulmedford
check on the 7.5A fuse for 12 V, and check the redand orange wire for 12V. its somethig simple you didnt connect
Old 01-12-2024, 05:40 PM
paulmedford
also check the main 40A fuse
BrandonSmith (01-12-2024)
Old 01-12-2024, 05:45 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 5,001 Likes on 4,192 Posts
What did you get 12.9 volts on the battery with?
Old 01-12-2024, 05:52 PM
EZ_Glide's Avatar
EZ_Glide
EZ_Glide is offline
@Jackie Paper used a multimeter and put probes to terminals. Should I get 12v when testing at that 40 Amp and 7.5 both just putting terminals in the holes? I didn't pull the main 40 or 50 Amp fuses at first but after no power just now I did remove and put it back in.
Old 01-12-2024, 06:09 PM
paulmedford
ground the black lead and the red lead should read 12v on either side of the fuse with the fuse in and on one side with the fuse out
Old 01-12-2024, 09:07 PM
Chasingdrakes's Avatar
Chasingdrakes
Chasingdrakes is offline
The flywheel slows down under compression. Slight as it is the ecm senses this slow down and fires the plugs.
Fat11Lo (01-13-2024)
Old 01-12-2024, 09:45 PM
WONKEY's Avatar
WONKEY
WONKEY is offline
Received 1,774 Likes on 820 Posts
Check your fuses with the multimeter, check all you ground connections. Make sure they are actually connected. When you say you rebuilt the engine what did you rebuild?
Quick Reply: Testing for Spark on M8 touring
