Testing for Spark on M8 touring
#121
Thanks for collecting the posts.. Since it didn't change could is be that the valves were hung open or I guess it's possible that he did not disconnect the ACRs. I leak test might help determine if there is valve leak tho a stuck compression release will leak air into the exhaust port.
#122
That's why I suggested to loosen both pushrods completely and pump air in the cylinder to see if there was significant valve leaks.
He was going to readjust the pushrods anyway, and he has the hose from the compression tester on hand, just remove the schrader valve from the end and pressure it up.
No need to wait for a leakdown tester.
Max Headflow (01-17-2024)
#123
Hey all, got the dowel out since I wanted to tear it down and make sure we're all good. Some stuff I saw reading the new posts, all of the parts I bought should be a fit. Was an s&s kit for the 2017 model, new flywheel, pistons, only thing stock really is heads (stock valves new everything else in there but breathers) and crankcase. Can give more specifics if you need not sure what helps. 4 3/8 stroke, 4.250 bore. Oil test when I tested compression didn't lead me to think piston rings are issue. Heads definitely may be problem, I want to get compression to where it should be then can focus on firing it up? Am renting a leak down tester tomorrow. I have the intake and exhaust off so I'm going to try blowing air in spark hole with piston in compression (what I was doing before dowel incident...). If I understand correctly, a slight hiss is ok from either intake or exhaust but a full blown air stream is very bad? Am going to test ckp while cranking to see if voltage changes with each crank just to check that (possibly) off the list. Who knows maybe with me testing it down and rebuilding it'll work
#124
#125
#126
#127
#128
@Schex I've readjusted pushrods with no change, I've watched a few videos and I'm doing exactly what they do and according to the install instructions. They turn by finger in TDC and are solid when turned to other cylinder if that sounds right
#130
That is the 124" big bore kit right? I ask this because if it happens to be the 128", the pistons would not go all the way to the top of the cylinders and would kill the compression, they would be about.065" down in the hole at TDC.
The bike was running before the engine work?
I was also curious why the heads had to be removed after they where torqued down.
I read where the bike wouldn't power up at one time, what was done to remedy that?
For the electrical problems, try rebooting the bike, turn on ignition switch, remove the Maxi fuse, turn the ignition switch off, wait 30 seconds and reinstall the fuse, wishful thinking, it's a dang computer you know.
paulmedford (01-17-2024)
