PV-1B vs PV4
PV-1B vs PV4
The PV1B comes with its own computer, so to speak. $550. The PV4 uses you phone, and is about $150 cheaper. $400
PV1B has auto tuning? And can be dynoed? Where as PV4 is just loaded maps supplied by fuel moto??
Fuel Moto can flash it for $250, and re-flash if needed. When weighing costs, you think for another $150 I can get PV4. But from a tuning perspective is just loading maps? I used to tweak maps, but I think I am just going to go with whatever fuel moto gives me. Both would give me the ability to read codes, and data log, and flash would not. I bought the SERT for that reason, and never used it that way. Just pull codes from dash.
You do have to factor in cost of dyno time. So that PV-1B, is $150 more plus dyno time. Which I am not sure I am going to spend the money. It is an older bike, and when I open it up, I suspect there will be a lot of nickel and diming.
I do get to Appleton on my quite often on my bike. But this build would be done in March or April, which weather is very hit or miss, especially for that long of ride.
I am going to talk to fuel moto, but was curious what people here have experienced.
2007 70k miles, SE AC, fat cat, going to port heads, TW222 cam, I may or may not bore it. Raising compression slightly with .030 head gasket. But keeping it lower compression.
I am rounding off on costs.
https://www.fuelmotousa.com/i-238999...2FFLT%20MODELS
https://www.fuelmotousa.com/i-206348...2FFLT%20MODELS
WOW, you're going to get so much help from people around there they're going to trip all over themselves to help you out.
I can see the bus loads of your fans showing up at your door to have the pleasure of being in your presence.
For we are not worthy of your intellect!
You truly are the one and only messiah with the unmatched knowledge of everything under the sun and moon!
We have all seen how you are never wrong about anything you speak of and are in awe of your powers of the English language.
And with all your knowledge why would you be asking us poor low life souls for help?
That seems so beneath you........
NorthWestern (12-30-2023)
It seems I have failed, because only 20% of this thread is on topic, and I suspect it will just get worse.
Received 22,178 Likes
I started this thread because you filled the other with a bunch of grab ***, and nonsense. I was hoping if I limited to just tech talk I could avoid people like you. Or at the very least have a discussion before you found this thread.
However, just to help you out and provide something on topic I provide these links so you can do further research yourself and try and figure out what fictitious tuner you want to by for your fictitious motorcycle.
https://duckduckgo.com/?q=difference...=v379-1&ia=web
https://university.fuelmotousa.com/s...-power-vision/
https://www.dynojet.com/pv4
I have not had any experience with Power Vision; however, had a SERT on my 2007 FLHTC when I upgraded it from 96 CU to 103 CU.
Happy New Year & Happy Researching!
I already have a SERT. I was trying to limit this a technical discussion and hoping you two butt buddies would not find your way in, until after it was done like the thread I started with.
I also though maybe I would get some people that had experience with the products. So far I crapped out on this thread.
Yes, you think I am researching BUYING a tuner for a bike I do not own. Do you know how stupid you sound?
Fat11Lo (12-31-2023)
The PV1b is stand alone?? PV4 needs internet?? Does it need internet to load the map, or to just download it to phone?
This was a deal breaker when I bought my scanner. My bike is somewhere without cell coverage. Not sure if outside of shop it would have enough coverage. I could drive it few miles, taking it easy, and probably be ok.
