Throttle lag
Throttle lag
Folks, my 2018 Sport Glide with the M8 107 has developed a lag/hesitation off idle that is very annoying. My Power Vision reads throttle position from 0% [idle] to around 8% when the issue happens. Makes smooth cornering pure misery. It also seems to be a bit more prevalent until the engine is up to temp [+/- 240 degrees]. Anyone had this issue?
Thanks,
Charles
Thanks,
Charles
not familiar with this system
is it a true fly by wire or does it have an idle control servo
fly by wire does not need a IAC so it controls idle by blade angle and should not read zero. there is usually a stop that prevents the blade form actually touching the body but it is a nat's *** clearance.
also FBW when shut down will adv the blade for the next start cycle and could be 8>14 %
on old system not FBW, the tps was biased a few volts, that was before the % measurement thingy came in
you might have to go back to basic and go from there.
also, might check fuel pressure as it will do all sorts of things
Thanks,
Charles
Thanks,
Charles
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
The following 6 users liked this post by fuelmoto:
2500hdon37s (11-20-2023),
Glenn Gorman (11-23-2023),
M Oclaf (11-21-2023),
Max Headflow (11-20-2023),
Slingshot383 (11-21-2023),
and 1 others liked this post.
