Front fender tip light ?
I have a 99 RK, and the front fender tip light went out. I had some people telling me that my tip light was flashing off and on, and I thought it was a loose or bad bulb, and a few days later it wentcompletely out, so I went and bought a new bulb to replace the old one, but it's stillnot working. I have taken the headlight off and checked the wiring connections and everything looks good.Hasanyone else had this happen to them ? I have not taken the front tire off yet to check the wires to make sure they are not worn. There isn't a separate fuse for this front tip is there? Suggestions?
RE: Front fender tip light ?
The tip light wiring came loose and chaffed through on my '05 EGC. I ordered a new wire, which required re-using the fairing-end connector. To replace it you need to remove thebrake calipers and front wheel, I also removed the fender for easier access. I used marine adhesive to attach the wiring to the fender instead of the stick-on holders, it ain't goin' nowhere!
Gregm
Gregm
longlakehouse
Electrical/Lighting/Alarm
10-23-2009 07:23 PM
