Engine stalls when battery is disconnected
Old 08-11-2023, 07:08 PM
M Oclaf's Avatar
M Oclaf
M Oclaf is offline
Received 5,803 Likes on 2,678 Posts
Originally Posted by SofttailBob
Your car battery is trying to charge the motorcycle battery at the same time you are also putting a load on it trying to start the motorcycle.
No, as I mentioned, I disconnected the MC battery first.
Motorcycles have a stator, not an alternator. I know, I should have said "stator."
I have no doubt that I need a new battery. It is five (5) years old. Funny thing, but the original battery lasted 14 years! Always kept a battery tender on it, just like this one.
Long battery life is an anomaly. Most folks get 3 years. Cars or bikes.
It also seems most “clicking” issues I read about, 9 out of 10 times it’s the battery.
Get a new battery and as noted, leave it alone, just ride the bike.
Old 08-11-2023, 07:17 PM
WONKEY's Avatar
WONKEY
WONKEY is offline
Received 1,772 Likes on 819 Posts
Originally Posted by QC
Why are you using a car battery to power your bike???
You can use a car battery to jump your bike, just don't have the car running.
The following 2 users liked this post by WONKEY:
tngarren (08-12-2023), WP50 (08-12-2023)
Old 08-11-2023, 09:02 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,420 Likes on 5,019 Posts
All modern motorcycles have alternators.
The following 2 users liked this post by Dan89FLSTC:
eighteight (08-14-2023), propflux01 (08-17-2023)
Old 08-11-2023, 09:05 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Now you did it....
The nuisance will be here soon to dispute that with his own facts...
MURPHCC1 (08-12-2023), TwiZted Biker (08-13-2023)
Old 08-11-2023, 09:14 PM
QC's Avatar
QC
QC is offline
Received 19,803 Likes on 9,866 Posts
I get that, have done it. Just don't understand why one would use a car battery to keep the bike running. What does this accomplish? Maybe I'm just being dense tonight.
Old 08-11-2023, 09:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Screwing around with jumper cables accomplishes nothing.
Jumper cables are not troubleshooting tools, but they are an opportunity to screw something up...
smitty901 (08-12-2023)
Old 08-11-2023, 10:19 PM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,548 Likes on 6,277 Posts
https://www.uti.edu/blog/motorcycle/...eration%20task.
Are they considered alternators? Or are they a little different in function? I’ve never had a car die after starting, even though it had a bad battery. I have had that happen on my motorcycle
Old 08-12-2023, 05:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The rotor and stator on a Harley Davidson produce Alternating Current, yes, it is an alternator, but of course not like in a car, where the parts are all in one replacable unit.
The voltage regulator turns the AC into DC, and controls the voltage.
The other day while out on the bike, I saw something on the road ahead at an intersection, as I rode by I saw it was a car alternator...
The following 3 users liked this post by Dan89FLSTC:
Since 1968 (08-13-2023), vicsponjr (08-12-2023), WrenchinRider (08-12-2023)
Old 08-12-2023, 08:25 AM
bustert's Avatar
bustert
bustert is offline
hd uses a PMG
it is not an alternator since it has no field forcing capabilities. the only hd that had an alternator was the shovel and only a couple of years.
a PMG is fixed and output is in direct relation to rpm. that is why the engine stalled but if you look at the schematic you will find it is tied in before the battery and technically the engine does run off the PMG with the battery making up the short fall. on the PMG unlike the alternator, spikes are more reserved since it cannot go full on, the alternator will go full on since the regulator sees no feed back as to voltage level.
but there is one thing to consider with electronics as voltage goes down, amperage goes up so there is a possibility of damage.
do not rule out a bad connection or a bad contact in the starter solenoid and or relay.
jumping with a car battery and same issue points in a diff direction.
springers4ever (08-12-2023)
Old 08-12-2023, 03:27 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Whether the magnets are simple permanent type or electromagnets, the unit does the same thing, it produces alternating current.
Quick Reply: Engine stalls when battery is disconnected
