Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I did not mention that I have a map which is working fine so generally if the hardware is ok and numbers do not change map is just not TT enabled. Am I correct?
What if only CLI numbers do not change? Also not TT enabled map? Thanks.
