Spark Plugs
Old 05-19-2023, 10:37 AM
cowpoke's Avatar
cowpoke
cowpoke is offline
Default Spark Plugs
Best plugs, EVO 80ci
for a 99 evolution Softail custom 80 cubic inch.
Maybe somebody has put up a survey in the past that might be available not sure if I've seen that?
Any case , trying to sort through all the different plug varieties copper, copper core, platinum, platinum plus, iridium,,
what's your experience and thoughts on all these variations?
Old 05-19-2023, 10:42 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,608 Likes on 2,727 Posts
Originally Posted by cowpoke
Best plugs,
While there may be some minor disagreement, general consensus on the forums, in my observation (and my experience), is that there are no magic spark plugs. Use Harley plugs.
I think there was a guy that used aftermarket spark plugs, claimed he got fewer colds and lasted longer in bed, but difficult to confirm.
The following 6 users liked this post by Keithhu:
ahhlou (05-19-2023), Oko (05-19-2023), porkster (05-25-2023), RK4ME (05-19-2023), strych9 (05-19-2023), YZR (05-19-2023) and 1 others liked this post. (Show less...)
Old 05-19-2023, 11:18 AM
hardheaded's Avatar
hardheaded
hardheaded is online now
Received 2,633 Likes on 1,628 Posts
I used Champion plugs for years in my Evo's, never a problem.
The following 2 users liked this post by hardheaded:
86glider (05-19-2023), SMR65 (05-20-2023)
Old 05-19-2023, 11:26 AM
Trumpet's Avatar
Trumpet
Trumpet is offline
HD plugs, inexpensive and work.
Old 05-19-2023, 11:31 AM
GOGOBECK's Avatar
GOGOBECK
GOGOBECK is offline
t150vej (05-20-2023)
Old 05-19-2023, 11:51 AM
brakeless's Avatar
brakeless
brakeless is offline
Received 5,688 Likes on 2,725 Posts
Multiple forums will get you the same answer...
Keithhu (05-19-2023)
Old 05-19-2023, 08:36 PM
Sparkules's Avatar
Sparkules
Sparkules is offline
Stock plugs or the Champion equivalent for the EVO work just fine, remember the engines were developed with a specific spark plug you won’t do any better and may do worse. Example, is the heat range and electrode design exactly the same? Extended tip is that way for a reason. If you substitute a plug with a flush tip not a wise swap, buddy did that on a boat motor and it ran terrible.
brakeless (05-20-2023)
Old 05-20-2023, 10:21 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 14,349 Likes on 6,143 Posts
I’ve played around with different plugs over the last 25 years or so and IMO it’s hard to beat the OEM Harley plugs.
Cheap and they work well. Can’t beat that.
Old 05-24-2023, 05:57 PM
Rodent66's Avatar
Rodent66
Rodent66 is offline
This topic comes up a lot. I really like and use NGK plugs, and I installed a set of NGK iridiums in my 16 FXDB, only to have the EMC pull ignition timing—-what da….. so I tried NGK regular ones , same thing happened. A couple of guys on this forum said I was full of crap. Well they probably have a different set up, don’t know ( or care). The Ion- sense these bikes are equipped with do not like any thing but OEM. You can ohm out the OEM Champions and then others only to find extreme differences ( if that means anything or not). What I do know is that the OEM Champions work right , don’t retard the timing like the NGKs did and runs just fine.
lightweight bob (05-29-2023)
Old 05-24-2023, 09:15 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,420 Likes on 5,019 Posts
Harley Davidson 5R6A
Champion RN12YC
Quick Reply: Spark Plugs
