2014 streetglide not starting
Hello all.I have a 2014 streetglide that's not starting just cranking after vance&hines fp3 map upload.I installed vance&hines full exhaust and went to upload the map but just kept getting a error.So I was messing with the app and went to customer support and uploaded my current map to them that worked.So I tried to upload autotune that worked but after the upload I got a the notorious P light on the dash cluster and the bike just cranks and cranks but not starting the bike started fine yesterday before all this.When I looked at the error codes on the fp3 appNow I also have 2 tps error codes I've talked to customer support and they basically told me to do the things I already did like pull the fuse for 20 mins reset the error codes etc... and still no luck.I'm hoping my battery is just to dead to fully crank it over even tho it cranked and cranked.hopefully someone can help me.Thanks
