No Spark & Dont Know Why
No Codes I am able to see. It is my understanding a deeper review of codes is only seen with the H-D Diagnostic tool. Gonna tuck tail and load it up to take to dealership where I expect they will plug in and tell me what its gonna cost me to play.
This is the 1st time in my over 40 years riding 6 different Harley's that I cannot troubleshoot and fix my problem. Very Humbling.
Funny you should ask that.... I was noting fuel pump on before trying to start and tried 1 last time before loading into trailer. I cant say that I verified it was running after cranking though.
The 1st thing the service manager noted was the fuel pump is now not running when the key is turned on. A new failure mode and all I did was load it and transport it 35 miles.
Problem solved - Dealership found the security system module tripped and for some reason the fuel pump relay that was working fine before I loaded in trailer had stopped working when unloaded at dealership. Replaced 2 modules and would start but poor performance. Found Power Commander V was faulted. Removed PCV and had better performance but stock tune. Replaced with Power Vision and dyno'd at 95hp, 108 Tq.
When I was trouble shooting I noticed 1 battery terminal was loose. I am thinking that loose battery terminal started the chain of events eventually faulting out 2 modules and the PCV. Of course when I installed the battery after checking the coil the damage was already done. I dont think I had checked the battery since it was installed in 2020. Seems I should make that part of my annual preventive maintenance.
