Need a New Battery, Need Suggestions, HELP
'02 Softail 98" motor, 9.8:1 compression, (3.6-3.7 gearing = 22 tooth comp. sprocket)
Need a recommendation for a better than average battery with *****, (preferrably 350+ CCA), that will fit.like the stock one. Can anybody recommend one?
Thanks.
V1
Thanks.
V1
RE: Need a New Battery, Need Suggestions, HELP
mikengina, your solution is...........RIDE THE BIKE MORE THAN EVERY COUPLE OF WEEKS!!!
velocity, look into compression releases and different pinion/ring gear ratios......... usually those high CCA batteries are good initially, or for 2-3 attempts at starting, but if it gets old (6-7months for those batts) or you crank a little more than usual, the batt dies and leaves you stranded.................... high output batts are usually more problems than they are worth.
