Dyno Tune or Thundermax?
Old 03-29-2023, 10:35 AM
Fat11Lo's Avatar
Fat11Lo
Fat11Lo is offline
Originally Posted by Tcrafty
If it can't, someone forgot to tell my Tmax!
I think the biggest hang-up is understanding what is meant by "Auto-Tune". It AUTOmatically adjusts the A/F ratio to whatever is prescribed in the tables.
Using terminology like the bold type is what I believe perpetuates the misconception about tuning devices, it's not changing the AFR it's adjusting the multipliers to change the pulse with of the injector based on feedback of the O2 sensors to target the programmed AFR table
It doesn't AUTOmatically OPTIMIZE the A/F ratio for best performance and fuel economy according to YOUR bike. Neither does any other tuner, OEM, or aftermarket.
This I agree with to a certain extent, "autotune" is a misleading term for a process used to adjust your VE and really is only a first step of a tuning process
Tell it what you want (timing & A/F ratio) and it'll make it happen. And, a whole lot more too. IMHO.
can you elaborate on this?
  #42
Old 01-12-2024, 09:12 AM
DiamondYoda's Avatar
DiamondYoda
DiamondYoda is offline
Stage II
Originally Posted by south69
Just installed a 124 kit in 2017 107 M8 road glide. Looking for tuning options. Local dyno guy said he would flash a tune on the dyno for $850. Been looking up other options and the Thundermax pops up a lot.
Would you go a dyno flash or go thundermax?
or what about the powervision? With auto tune
wait until you can go to a bike show and watch them tune your bike on a dyno. These shops probably just down load a map and take your $800. Or if they let you watch them do the dyno at your local shop, then ok. Otherwise, be careful!
  #43
Old 01-13-2024, 08:00 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
​​​​​​Wow! I don't even know where to start. So I won't. Besides, it looks like Fat11Lo has it under control dispelling yet another myth here.
QUOTE=DiamondYoda;21523403]wait until you can go to a bike show and watch them tune your bike on a dyno. These shops probably just down load a map and take your $800. Or if they let you watch them do the dyno at your local shop, then ok. Otherwise, be careful![/quote]
This doesn't even deserve a response.
  #44
Old 01-13-2024, 08:07 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 6,009 Likes on 4,062 Posts
Another lamb for the herd...
Then don't. Cuz you don't know what you are talking about 1/2 the time anyway.
The following 2 users liked this post by Max Headflow:
harpwrench (01-13-2024), jbarr1 (01-13-2024)
  #45
Old 01-14-2024, 07:56 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
I'm not the one who's engine ended up in pieces. Are you?
Must be your L33T tuning skills that are better than a competent tuner with a dyno, huh?
Or maybe the stock pump and plate that you say couldn't be better.
The Thundermax is great but you still need a tuner with a dyno or you're just guessing at some fine tuning that can make the difference between a good tune that runs good and an optimized tune that runs great and gets good mpg. Some people will just insist on spending money on a build then skimp on the part that makes it all work best to save a few hundred bucks.
  #46
Old 01-14-2024, 10:11 AM
Max Headflow
Never had a tune that's blown a motor up.
rigidthumper (01-14-2024)
  #47
Old 01-14-2024, 05:45 PM
Max Headflow
Originally Posted by hrdtail78
Why is the Tmax always talked about as it won't benefit being in the hands of a professional tuner? On a $30,000 machine designed to hold bike in steady state for tuning and gives the operator feedback that can't be gotten anywhere else.
IMO one of the best features about Tmax. It's live tuning and no reason to shut down the bike for a reflash. The biggest downfall. Alpha n ignition. Not that one needs to 100% agree but how can one evaluate if not understanding these assets and liabilities?
I don't ever think I've read or heard that Tmax won't benefit from running on a dyno.. One of the best things about tmax is that you can tune on a dyno if you have one.. Change AFR / timing on the fly.
  #48
Old 01-16-2024, 08:08 AM
Fat11Lo's Avatar
Fat11Lo
Fat11Lo is offline
​​​​​​Wow! I don't even know where to start. So I won't. Besides, it looks like Fat11Lo has it under control dispelling yet another myth here.​
My issue isn't with Thundermax, but the "autotune" myth. Thundermax has been a a capable tuner in the right hands and is very useful in boosted applications. I only have one experience using it and it does learn and when you apply the corrections the bike does improve. I used it on a Zipper's cam install and the corrections were not that drastic, wish I had more time to play with it. But I believe just as with any other tuning device you have to have a good starting map and you have to have developed enough knowledge to know when things are not right and stop instead of keep riding the bike. My biggest fear with this "autotune" marketing is that a person spends good money on engine mods believes the "autotune" is going to give them the same results as a dyno tune and goes out riding their bike and destroys their new parts thinking the "autotune" is going to fix their bike
98hotrodfatboy (01-16-2024)
  #49
Old 01-16-2024, 10:59 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,463 Likes on 3,641 Posts
The thing is you have to have some knowledge as to what a build required... Think about it, when there was nothing but carbureted bikes we threw together some parts and said **** I'm probably going to need at least this much jetting because I'm moving this much CFM and my RPM range has changed also.. oh yeah and I'm probably going to need a little less or a little more timing depending on what my spark plugs tell.. All right again you're going to need to have some knowledge and how to read them to get the proper adjustments just like anything in life...
I will go with the rule of thumb that there is no real auto tune.. It still requires user input..
The same can be said with tuning a bike on a dyno.. If the user input is negligible, so is the tune..
The following 3 users liked this post by 98hotrodfatboy:
Fat11Lo (01-16-2024), HDOflhx (01-16-2024), porkster (01-20-2024)
sandrooney
2018+ Softail Models
06-02-2021 12:01 PM
koolbreez
The Dyno Room
03-19-2021 10:52 PM
slim jim 1954
04-16-2018 07:20 PM
anubisss
07-01-2009 09:30 PM
puma
05-20-2008 03:32 PM
Quick Reply: Dyno Tune or Thundermax?
