No crank, no start
No crank, no start
Hello, i recently purchased a not starting 2015 Street 750. Thought it would be very easy to get it running. I purchased a obd2 connector to read the codes. I use this connector on the EOBD of my car code reader. My scanner can not connect to the ECM. I also purchased a used ECU thinking that it could be the source of my problems. When i remove all the connectors of the ECU the check engine light stays on. When turning the ignition on the ignition relay turns on but the system relay does not engage. I would appreciate some help to get it running again.
Since you say it doesn't crank, you need to charge the battery and get it load tested.
I don't know why you bought a code scanner since the bike will read codes through the speedometer. Harley Trouble Codes
The 2015 Street 750 does not seem to be a very popular bike on this forum.
Based on the limited information you provided and taking a wild guess that your motorcycle battery has been tested and reported as OK.
Is it possible that problem could be security system related?
Do you have a key fob with a battery inside the fob that has been tested (plastic tape removed).
Obviously the key fob would need to be married to the security module.
I am unaware of a car ECU scanner working on a Harley so take that out of the equation.
I will also take another guess that you are disconnecting battery when addressing the disconnect and reconnect of computer parts.
khui
06-18-2015 07:19 AM
