Hard starting with Tmax on 2003 RK with S&S 124
I've been fighting this issue since I had the Tmax installed. I'd originally built and installed the engine and had the S&S IST on it but was convinced by a local indy to install the Tmax. Well, after diagnosing a few issues (regulator died, other fueling issues) I've gotten the bike to more or less work (still playing with why it likes to not idle when its hot, but only sometimes) but am still having a hell of a time getting it to start. So, here's where I am.
The bike has:
My theory is that having the CR's open lowers the compression ratio. That, along with the easy start cams, has it quite low. Somehow, the bike's AF ratio is perfect to start on this super low compression ratio, but when the CR's are left close, that compression ratio is raised and the air fuel ratio to start the bike is no longer any good. Now, I have read in some places that compression ratio doesn't affect air fuel ratio. But, I'm still thinking that this issue has something to do with these two factors.
Am I crazy? What could it be? Does anyone have any experience with any of this (yeah, I know, the bike is 20 years old)?
The bike has:
- S&S Easy Start cams
- compression releases
- All Ballz starter (which can easily spin the motor without the releases or the easy start cams - I know this because before I rebuilt it, it had neither)
I would suggest doing a compression test with CR's on and off. I see no reason why both are needed. Give details of engine build.
I would leave CR's off and add some timing to the cranking. Can be done in the ignition vs engine speed table. I think default is zero. But the zero and 269 (I think ?) rpm can be raised.
porkster (03-17-2023)
It's an S&S 124, with S&S Gear Drive 640 Easy Start Cams and running 10.5 Compression ratio. Standard S&S heads for the 124.
I will give the raising of the timing a shot and report back soon.
after doing the compression test that hrdtail78 has said, what are the results,,,,this can help make sure that your cam timing is correct from the start. if its good, the next thing to think about is how good is your starting point base map? if its only so so, or not close at all, you need some assistance. If there is not something that is pretty close to your build in the list in the software, contact TMax tech and see if they cant provide you with a base/starting point map that will get you closer.
m
m
porkster (03-20-2023)
It was a timing issue. I added some timing to the zero and 269 RPM and it started. I waited a day, tried it again and it started. So, I may have some more fiddling to do, because it never starts on the first crank, only on the second (which I seem to have to hold onto the starter for longer than I would like). Thanks for the help @hrdtail78
The following 3 users liked this post by cobaltking:
skydoc
10-10-2009 07:14 AM
