Bike Wont Take A Tune With New Cam
#51
#52
Only one? I thought each cylinder need an o2 in the pipe? I'm not a tuner. Was just a thought cause bikes will run but they will run like crap if they are plugged into the wrong connection.
Glenn Gorman (02-06-2023)
#53
These bikes would throw codes if the sensors were bad or installed incorrectly, i'd assume.
#54
Is that shop going to load the tune for you?
#55
Yeah, he knows it wasn't right when I left and agreed to tune it. He said to bring it down on Friday, but I'm not sure how long it will be until I have the tune from FM. Maybe today or tomorrow.
#56
I apologize, you're 100% right. One sensor per cylinder/header pipe. I was thinking about how the shop tuned one at a time. A lot of my old Japanese bikes have one sensor where the headers join together.
#57
Lonewolf176 (02-06-2023)
#58
You do as was addressed. I hold rpm break point and slowly close throttle until I reach a throttle position that gives me highest KPA. Throttle position for peak KPA is peak KPA. The baro of the day shouldn't affect where this peak KPA is found. Also, when finding peak kpa at say 2750 with 100kpa for baro of day. You don't see a peak just at say 45% TPS. That peak seems to held for several TPS percentages from say 43-48% and is TB size, cam, pipe blah blah dependent.
I think you have in mind what to do for best performance mapping the TGS to the TPS. I was thinking more along the lines of getting VE data for areas beyond optimum performance. Do they even need to be mapped?
#60
Hahaha...well he sure as hell isn't saying anything if he thinks that might be the case. It's a small local shop. He does have a storefront, but apparently he lives there as well. He has done a lot of bikes and some of the local clubs here and guys that I ride with have said he is good.
I have definitely considered the possibility more than a few times over this past month. I have reached back out to him multiple times while it was at the dyno shop(which is a block away from him) and apparently he met with the guys at the dyno shop and they must have had a not-so-friendly interaction because they both stated to me, separately, that they will never communicate with eachother in the future. I think the dyno shop believes he screwed the timing up, and the mechanic likely thinks the dyno shop doesn't know how to tune a Harley. Unfortunately, neither of then habe even attempted to offer a solution because they're both stumped. I just figured it must be a tune thing, since the bike behaved so differently on each map and screwing up a cam install with alignment marks is a tough thing to do when you have experience.
Would that not screw the bike up throughout the whole RPM range though? Whenever FM gets that map over, I'll be able to shed a lot more light on this situation. If it still has an issue, then I'm going to swap out the cam anyway, and that eliminates the possibility of a timing error. I'll be sure to post here if I find that he missed a tooth though
