how can I add more columns for RPMs lower than 1000 in WinPV?
Hi all
I'm a newbie and this is my first time using WinPV/PV. I got a question, I was checkin' out the Spark-> Spark Advance table and noticed the lowest RPM is set at 1000. Is there a way to add more columns for lower RPMs like 900, 800, etc?
I already got the code from DJ to unlock lower RPMs, but I wanna make some adjustments for the even lower RPMs, you know, for the idle part. I ain't tryna do nothin' dumb, I just wanna know if it's possible to add more columns for lower RPMs?
Appreciate any help, thanks.
Really. Needs to be 950-1000.
For proper oiling and so the charging system can keep up.
When I put a Powervision tune on my 2020 107 that was idling at 850, it bumped the idle to 950-1000. My stock ‘22 114 idles at 1000
