Power vision questions reset trim levels and scale cap?
I would cap it, then export it to a tune slot. After that load that tune into the ECM then auto tune it again and do the same process. If you scale it Dynojet software will automatically change the cubic inch of the motor in the program because of the high VE tables ( over 127.5) that auto tune is trying to change. I myself would keep cap and do what I first said..
Couple of questions though first, Is this the Bike in your Sig? If so with all that work, you didn't Dyno tune it??
You should always state year model and build specs to start a thread like this so most can offer up the proper Advice...
I had it tuned good got lots of hits in auto tune then scaled the map and exported it and remapped and now it’s running crappy again in first gear sputters and choppy
it was dyno tuned but they couldn’t get the rough first gear taken out advised me to get wide band sensors
I asked you to state your build and again you did not fully describe it.. What cam do you have because that will make the most difference in the way your motor runs.. How familiar are your with Harley's and do you understand high performance builds and how they are supposed to run??
So what cam?
I had the same issue with my build on my 2013 in my Sig. Your system is doing all it can do.. The ECM see's it rich and is now leaning it out.. You need to understand that when you do an auto tune with the Auto Tune Basic that it sets the entire AFR map to 14.6 because your narrow band sensors can only read AFR's from 14.3-14.9:1.. Then the ECM tries to calculate your necessary VE's and air flow based on MAP/kpa readings and adjusts everything back up to a leaner setting that only the Narrow band sensors can read. You will need to reload the original dyno tune..
So what cam?
So what cam?
dave Mackie 575l cam
big sucker 2 intake
d&d fat cat
like I said I did a good auto tune and had it running mint lots of hits almost the entire screen was red from hits but then scaled that map and it’s running crappy again in first gear.
No I’m not expert in engines
My 107/Tman 590 build was tuned on a dyno by hrdtail78 @ C&S Speed Shop and the displacement is 117. Way too many cells would've capped at 127.5 making the VE cells inaccurate. Actually even the base map Jamie at FM made specifically for my build when I bought the PV was set as 117cu.in and I STILL have some cells at or near 127.5.
But then my heads flow real well...
