Dead bike
Dead bike
Greetings from NH! I'm in a bit of a trouble here. I took the bike out yesterday, had the Oil changed and came home. I left the bike outside for a bit to cool down before I moved her into the garage, and now I have No Power & I can't get the Forks to unlock to move the bike.
I've checked the cables to the battery, everything is tight as it should be. I had an ignition issue this past summer, the local dealership said they fixed it.
It probably had grit in there, but wet lubes only attract more grit. Sometime, you should pop it, spray it with brake clean, Q tip and use whatever to clean it all out, then look at a graphite lube. This is in the manual.
Slingshot383 (01-02-2023)
inthechateau
08-25-2011 06:05 PM
