08 RK fuel Filter?
Hoi,
I should check for a manifold intake air leak.
Easy to check.
With the engine running at idle, spray some carburetor cleaner against the manifold inlet. (Where the rubber seals are.)
If the engine stalls or sputters, there is an air leak.
make sure that the carburettor cleaner is not sucked in by the air filter!
Easy to check.
