Stage 1 download again
05 Fatboy injected
I dont want to beat this subject to death but :
I bought Screamin Eagle II slip ons and am planning to go with the A/C
All the reading about SERTS, PCIII and the dealer Stage 1 download is certainly confusing. Is the Stage 1 suitable, acceptable, and dependable enough to go with the combination I am intending? This is all I plan to do to the bike and really dont want to spend the big bucks for something I dont need. Will it run hot or hotter than it does now? I am happy with the way the bike runs now and I just want it to sound right.
Thanks in advance.
MikeM
Thanks in advance.
MikeM
RE: Stage 1 download again
Let me modify that reply. (That one and this apply only to the "Stage 1" download.) It might actually run a tad hotter since it'll be making more power, if you run it so that it actually produces that extra oomph.
It will, by law, be just as lean as the day you bought it (assuming the dealer didn't break the law by modifying the emissions in some way for you prior to delivery).
The stage download from the dealer will add a small amount fuel across the board but the download is still on the leanm side forEPA. It should run better with the additions but the fuel map from the dealer is still on the lean side. It will be a bit cooler but not alarge amount.
The extra fuel would normally tend to effect some cooling. But in this case, there is extra air as well, so the fuel is added for the sole purpose of maintaining AFR. In the end the pistons and cylinder heads will heat up the same amount unless the extra power capability is put to use, when it will be generating more heat than before.
I believe the tendency to "feel" like there's less heat is the result of either using the same amount of throttle as before and going faster, or maintaining speed using less throttle. A pound of fuel mixed with a 14.6 pounds of air and burning is going to create the same amount of BTUs as it did before.
unyalli
07-21-2015 02:37 PM
