ThunderMax problem. HELP!!!!!
RE: ThunderMax problem. HELP!!!!!
Were you able to start the bike? The Thundermax will light up the low battery light normally. It's common for me to see the low battery light right after start-up. It quickly goes off after the charging system kicks in. The tmax either draws more juice or expects a greater voltage reading. I think it's the latter.
me is dumb
i didnt load the map cause i kept making changes to it in stead of getting a closer match so i thought it was loaded but it wasnt
and i wound up loading another map that was closer and it turned over it s alive.
thanks to all that helped me aand thanks to the tech guy at thundermax for helping me get the right map and loading it.
