2007 O2 Sensor Connecters?
Ok here is the list of connector parts from the dealer, however we are still missing the sensor end pins. Note the comment at the end.
72006-05 Socket Terminal (Qty 4) - main harness end
72007-05 Socket Housing (Qty 2) - main harness end
72011-05 Wire Seal (Qty 4) - o2 sensor end
72009-05 Housing (Qty 2) - o2 sensor end
The problem with the sensor end is that HD does not give the part number for the pins.
I had to make my own O2 eliminators for a PC III because I found a great deal on one without them only to find out Dynojet does not sell them separately for Harley. What I found was the legs of the resistors fit right into the female side (bike side) of the plug. From that point I used different sizes of heatshrink to protect from water and secure the resistor to the plug. Would there be a way you could hot glue or epoxy the resistors into the plug housing and use the legs of the resistors for the male pins? I don't know if this would work for you or not because I have not seen the bare socket.
