Plug wire resistence
1 2 many (05-15-2022)
If you have a concern, also mist them in a black garage or at night with it running. I have seen them light up like a Frankenstein movie from the heat cracked insulation.
On a TC 04 Softail, the longer 19" wire should read 4750-11,230 ohms. The shorter is 1812 - 4375 for the 7.25 cable.
JKSHYT (05-08-2022)
add a signature line on year model and all the letters.
If you have a concern, also mist them in a black garage or at night with it running. I have seen them light up like a frankenstein movie from the heat cracked insulation.
On a tc 04 softail, the longer 19" wire should read 4750-11,230 ohms. The shorter is 1812 - 4375 for the 7.25 cable.
