62 psi fuel pressure regulator
No special need, just seems that the higher psi would atomize the fuel better. Spent a lot of years working with diesels. Higher psi on injectors atomizes fuel better, giving better (more complete) burn of the diesel fuel. Better burn = more power from fuel used. Figured it would be the same with a gasoline system.
hummmm????
on efi, more pressure would reduce dwell time which can be +/- .
mechanical diesel or electronic injectors?
also, remember that the two are diff animals and inject differently during the stroke one being more or less a mixing vs flame thrower lacking better words.
in early days, increase pressure could add hp per given injector but that was in a all out situation when computers were stupid. today, computers are way smarter and can adjust dwell on the fly.
I have used one on a bike that had injectors at borderline of being tapped out. It worked for the application but doesn't make as big of a difference as one might think. We are talking 4 psi. Not much more fuel volume is added and the upped psi does raise dead times. End result was a dropped of about 4-5% in duty cycle. Which worked for the application but other mods where planned and bigger injectors were apart of it.
IMO getting injectors with correct spray patterns for our HD's is more important for fuel atomization, but people seem to go with stream injectors when building. So......
KevinKruuz
07-29-2012 07:12 PM
