Tune knocked out gear display
Old 01-09-2022, 04:30 PM
davekp's Avatar
davekp
davekp is offline
Default Tune knocked out gear display
Did my first tune with the SE street performance tuner on my '21 Freewheeler (M8 motor). The digital display in the speedo now doesn't display which gear is selected, but the RPM display is OK.
Any ideas?
Thanks in advance.
Davw
Old 01-09-2022, 04:31 PM
Ultra103's Avatar
Ultra103
Ultra103 is offline
Received 1,050 Likes on 539 Posts
Let the dealer fix it since it's under warranty
smitty901 (01-11-2022)
Old 01-09-2022, 04:33 PM
davekp's Avatar
davekp
davekp is offline
I don't think so since I did the tune.
Old 01-09-2022, 04:51 PM
roussfam's Avatar
roussfam
roussfam is offline
Received 7,220 Likes on 3,753 Posts
Are you sure the two are related?
Old 01-09-2022, 05:30 PM
davekp's Avatar
davekp
davekp is offline
I think so, since they both occurred at the same time- but it could be a coincidence.
Old 01-09-2022, 07:52 PM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
I believe you can reinstall the stock calibration and see if that fixes the issue. Let us know.
Bob
Old 01-09-2022, 09:11 PM
davekp's Avatar
davekp
davekp is offline
Bob
I don't know how to do this. Can you advise?
Old 01-09-2022, 11:15 PM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
Maybe the “Street Tuner” doesn’t allow changes to the gear ratios. You may need to purchase full feature tune like TTS or PowerVision to change ratios.
Let us know what you find out.
Bob
Old 01-09-2022, 11:28 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
Bob
The SE Pro Super Tuner doesn't. I'm sure that EPA limited piece of crap doesn't. In fact I know it doesn't. Did you actually change gearing? There's no possible way a tune, if you can call what the street tuner does a tune, could do that. That parameter doesn't exist.
Old 01-10-2022, 07:39 AM
b0fh's Avatar
b0fh
b0fh is offline
maybe he flashed a bike tune on the trike and the gear ratios are different? (just a wild guess).
since the harley tuner cannot change gear ratios, those are probably 'embedded' on the base tune - need to find the correct one.
FLTRI17 (02-10-2022)
Quick Reply: Tune knocked out gear display
