Tune knocked out gear display
Old 01-10-2022, 08:11 AM
davekp's Avatar
davekp
davekp is offline
Gear ratios are not an issue. Not sure how the discussion drifted there.
Old 01-10-2022, 08:20 AM
strych9's Avatar
strych9
strych9 is offline
Received 9,890 Likes on 3,702 Posts
Gear ratios are how the ECU knows what gear you're in so it can display it properly.
Have your dealer look at it.
Old 01-10-2022, 08:29 AM
rigidthumper's Avatar
rigidthumper
rigidthumper is offline
Veteran: ArmyVeteran: Navy
Received 6,580 Likes on 1,814 Posts
Verify you are using A41000999D map.
Old 01-10-2022, 08:37 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
Because when people change gear ratios, this happens and unless they correct the gear ratio being used in their tuning software there's no way to get it to come back. I know because mine disappeared when I put a 30 tooth solid sprocket on in place of the 34 tooth compensator. With the TTS Mastertune and Power Vision you can change the gear ratio you're using and the display returns.
If the ECM doesn't know what gear you're in it displays nothing. It was a possible cause of your issue. The gear ratio being changed in the tuning software to an incorrect one by mistake. But its not an option in the SE Software so.
Old 01-10-2022, 09:06 AM
davekp's Avatar
davekp
davekp is offline
I didn't change any gearing.
Old 01-10-2022, 10:43 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Right but...Nevermind.
Old 01-11-2022, 04:14 AM
b0fh's Avatar
b0fh
b0fh is offline
be patient gunner
OP, there are 'gear ratios' on the map/calibration you flash to the bike. you cannot see them in the shitty harley software/product/tuner (why people fall for that thing when there are still much better options available...)
but they are there, trust me.
there is also another parameter for the speedometer calibration to make it read correctly.
if you flash a bike calibration on a trike I believe it throws all these things off. you need a trike calibration, as another post indicated it should be 'A41000999D' - sorry I cannot help more because I never used the 'street tuner' myself for obvious reasons but bottom line make sure that the calibration you are flashing is meant for a trike.
good luck!
Old 01-11-2022, 05:18 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
Originally Posted by b0fh
be patient gunner
good luck!
Haha. It was late and my brain was in shut down mode. Not up to the task of explaining it in !aymens terms.
In short, what the ecm is seeing for gear ratios doesn't match what's being used, it goes blank..Trikes use different gear ratios. If the file you flashed to the ecm was for a bike the ratios in the file don't match what's in the trike. The ecm gets confused and the display goes blank because it has no idea what gear it's in.
It keeps trying tho. Mine occasionally flashes up a gear, in a moment of brilliance apparently, usually at real low rpms and just for a few seconds. I did change gearing.and use the SE Pro Super Tuner. where that parameter is also not available.
Old 01-11-2022, 07:30 AM
davekp's Avatar
davekp
davekp is offline
OK.
Starting to make sense now.
Old 01-11-2022, 09:06 AM
davekp's Avatar
davekp
davekp is offline
I just checked and I did in fact load A41000999D.
Quick Reply: Tune knocked out gear display
