Powervision with Target tune
I have a 107 built motor in a 2007 Road King that was tuned with power vision at the shop and also dyno'd. I recently put the icing on this build and installed Bassani's 2-1 Road Rage. Obviously it's not running correctly and needs to be addressed. Aside from bringing it back to the same place to just tune it I've been looking into just buying a PV module and see a lot of recommendations of adding target tune to really get a good running bike.
Would the consensus be that just buying the PV alone isn't going to be enough to get the bike to run properly with this 2-1 exhaust addition? The target tune uses the wideband o2 sensors which I know are used on the dyno so I see the benefit there. Does the target tune kit then stay installed on the bike once done?
Thanks.
Thanks.
Yes the Target Tune stays on the bike. You can remove the Power Vision but I leave mine on to monitor the engine with the gauges. Give Fuel Moto a call and they will set you up with a Target Tune kit and a Power Vision with a map already installed. Then you just install the Target Tune, flash the ecm with the PV, twist your right wrist, and enjoy.
Yeah, put it on and enjoy but that doesn't mean you bike is Inman great state of tune.
That's it? If only that easy. If we change the air flow through the engine. Meaning at some throttle positions more air will be moving, and some less air might be moving through the engine. Wouldn't timing also need to be addressed? Since KPA is a good indication of this air flow. Wouldn't throttle settings also need to be adjusted? What about acceleration fuel? This is base on straight pulse width. Wouldn't one want that tuned also? How about CDE tables? Would a 2-1 affect exhaust gas reversion and there for MAP readings?
Lol from what I understand and have read so far, the auto tune process either basic, pro or target using PV has you ride through all your different styles of riding and adjusts as it goes along. Then you have to apply those changes to the ecm after. Adding the target tune apparently does even more refinement. I see your point about all those things you brought up but a tuner at a dyno shop is essentially using the same power vision set up.
Here are some things a tuning product does not address and why a knowledgeable tuner will always do a better job.
Detonation when leaving from a long stop light. Most tuning devices will address this in the main spark table. Is that the best way to do it or the easiest way? Some will even go further and address this in Engine temp correction tables. Is this the best way to address the detonation?
High VE's in a certain area of the VE table. 4000rpm at 55kpa VE cell is at 127. Most tuning products will want you to up the cubic inch size of the engine. Is this the best way to address these high VE numbers or is there a better way?
IME Hitting a target VE is the easiest adjustment and the one with the most tolerance to be off with out effecting daily performance. Things such as timing have a less tolerance, harder for people to wrap their head around, no great tools in any program and will have more affect on daily driving. How many times do we hear about a bike running hot and the answers that come back is about fuel and how it needs more. Rant about lean conditions and EPA but the real cause is retarded timing putting heat into the heads through exhaust.
No doubt people can get a good running bike by auto tuning on the street, but if you think your are going to download a calibration. Hook up target tune and just ride. Good should be your expectations.
Steve Cole made a post about this very topic and I should have done a screen shot of it because it was the perfect explanation of why the target tune or pro tune or whatever device doesn't actually tune the bike. Nothing is a good as a good dyno tune. I've used maps from fuelmoto on other people's bikes and they worked well and those guys were happy with the results. Full disclosure...each time it was a package that fuelmoto has used many many times so they have the tune pretty close. Vary from one of their setups and your results may not be what you were expecting.
Stang951 (12-31-2021)
Maybe, but a lot of tuners at dyno shops don't use the Vision process of basic, pro or target. They collect data with something else and map VE with something else. Use the vision for tables and a key to flash the ECM. Yet, of the 3 options you have with Vision. It's only addressing the VE tables. A tuner is using his knowledge and his dyno as a tool for other tables.
