Preserve map
Preserve map
Hello,
I have some basic questions regarding preserving (saving) maps with a tuner.
My bike (FXFBS) has a Torque cam with a Dyno tune. I'm happy with it above 2500rpm but not below.
The questions:
- Is it possible to preserve (save) the tuned map which is in the ECU, so that I can re-flash it later if needed ?
I would think this must be possible but the manuals are not clear. When they write: the 'stock map', do they mean the 'stock map that came with bike when new 'stock map' or the map that is in the bike when the tuner is connected the first time ?
- Can this be done with a V&H FP3 ?
Thank you for your time.
Jef
The questions:
Jef
Hello,
The questions:
Jef
The questions:
Jef
DYNOJET Power vision copies the map and saves it you can restore it in about 45 seconds. I do however recommend you you copy it to you computer also . Simple to do just in case the unit ever fails.
Just in case you are thinking about restoring the factory Map for warranty reasons They will know the second the hook it up at HD.
If you plan to buy a Power vision I suggest getting it from Fuel Moto. When you order it on the form you fill in what you have done to the bike and they will include a preloaded map with it for you and will modify it for you free if you make changes. No better support anywhere.
I live in Belgium, for some reason the HD Screaming Eagle tuners are not available here at all and we can use the V&H, Dynojet, ... tuners without loosing our warranty if bought at a Harley dealership; so ordering with Fuel Moto is (sadly) not a good option.
My bike is Dyno tuned, I only want to be sure I can keep that tuned map, definitely saving the map to a PC as well.
Thanks for the info.
Jef
Jef
From the answers so far I see that the Power vision definitely is able to save the map (and meanwhile watched their video's for the procedure as well).
On the downside they don't seem to have a map for my configuration (or I don't find it) - all HD: SE air intake, SE-447 cam and Street Cannons - which surprises me a bit.
The V&H PF3 does have a tune for my configuration, but it seems that tuner cannot save the original map that's in the bike.
Jef
Jef
Jef
Jef
StevenRK
04-18-2012 10:08 AM
