CEL WITHOUT code...
I ran the code check w/ the run button in ON/RUN.
Code p0117 & p0118 appeared.
I measured for 5VDC at the plug and it's good.
Swapped the sensor for the original one since I still had it laying on the bench.
CEL is now GONE!
Seems like the new temp sensor was either bad from the start, or it failed rather quickly.
A new battery also seems to have helped w/ the hard cold start issue that I had before swapping the temp sensor.
CEL is now GONE!
07UltraGuy
12-24-2021 12:27 PM
