Starter problem?
Starter problem?
Hello everyone!
I own a 15 HD Sportster 48 with about 12k miles and wanted to I suppose corroborate an issue I'm having with the bike. I think I have a bad starter. Yesterday I went to go start her up after 3 weeks (on a tender) and I get a half turn. it engine stop again then on so it can prime, and hit start again and I get same half turn, maybe even less than half this time. Same step, and again hit start and this time CLICK! coming directly from the starter motor. I test the battery, 12.8 Volts, so I know that's not the issue. This has been progressive, as I think about 3 months ago, it started to SOMETIMES become a lil hard to start, so maybe that was the starter beginning to go out.
Does this sound about right? My question would be, is it feasible to rebuild the starter, or should I just buy a new one, and if so, where would the best place to buy one be? I'm somewhat handy, is this something I can tackle myself, or should I just have a shop do it can anyone recommend one here in the 818 (los angeles)?
Thanks guys!
Thanks guys!
You have a battery that is 5 to 6 years old. It may have 12.8 at rest, but under load it could drop too far to start the bike. Before you start swapping parts, you should first check all FOUR battery cable ends for corrosion and tightness. If they are all clean and tight, then take the battery to an auto parts store that can do a load test.
Max Headflow (11-28-2021)
I'm with pass rider. I'm so confident that the battery is junk that you should skip the trip to get it load tested. 5 years old and it sounds like it had a rough life...intermittent maintenance and probably alot of sitting around discharging not getting used regularly. Get yourself a good battery...don't go to Walmart in other words. Batterymart.com has great batteries for reasonable prices and they ship fast and free. You should check the new battery to make sure it's fully charged...most are not and a little time on the charger before being put into service is the right way to do it. Good luck
One more question: I have that pesky keyless fob, and the shop manual says that if I disconnect the battery, it must me ON (thinking it's so that it doesn't forget the fob when new battery reprograms.. Not sure if any of you have had any experience with that.
THanks!
EdPayne66 (10-23-2023)
Um..... So wah ha Happen was... LOL
I look at the negative terminal... nice and tight. I look at the positive... loose. Tighten slightly (well a lot) and then I go to start it. BAM, 1st try.
it's that Harley vibration!!
Anyway, thank you guys for the wise words. I'll make sure to always start with the Basics!
