Those who seen it all (No Start)
Old 11-16-2021, 07:33 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,464 Likes on 3,642 Posts
Originally Posted by Moses110
Thanks Marco, the dealership flashed into my stock computer after I paid a licensing fee for their Power Vision? The dyno tune was great, but I had a Woods lifter collapse and bent a valve. I wasn't going to pull it down now and not do what I planned on doing later later so here we are. Tonight I will go back over injector plugs to verify again and check the other plugs again as well. I will report back tonight or in the morning with results. Not above checking again with commitment, I can handle a dumbass mistake better than a issue that makes no sense. I'm sure the consensus is I did something wrong along the way, I hope that's the case but I really don't think so at this point after checking and rechecking. Thanks
Don't quite follow this statement in bold.. Did you remedy the bent valve cause if not I would think it to be a major issue and am thinking your valve lash is too tight.. It would explain firing out the exhaust..
Old 11-16-2021, 09:01 AM
Moses110's Avatar
Moses110
Moses110 is offline
The bent valve is why I had to pull the top end off. I just decided to go with the Muscle kit now instead of later since it was apart.
Daehawc
07-30-2016 07:13 PM
Seth21
04-22-2016 11:05 AM
thale756
03-13-2014 06:34 PM
Slider 51 Pan
General Topics/Tech Tips
07-05-2009 05:00 AM
Neckball
Exhaust System Topics
11
02-16-2008 09:11 AM
Quick Reply: Those who seen it all (No Start)
