SE Smart Tune Pro questions
Bike is a 2020 Road Glide Limited FLTRK with a SE Stage 1 setup to include the SE Pro Street Tuner. Have recently added the SE Smart Tune Pro and wide-band O2 sensors. This all went together well with the exception of the ill fitting rear O2 sensor hitting the transmission cover, but that’s for another discussion.
The SE software has you load a new base map calibration onto the ecm that the Smart Tune Pro works off of which includes the wide band O2 sensors.
My question is whether is a benefit to running a couple of smart tune recording sessions to update the calibration, load that onto the ecm and have the Smart Tune Pro work off a calibration that is more specific to the bike?
Thanks
Mike
Thanks
Mike
mthopton (11-14-2021)
There is very little dealer knowledge or support with the Smart Tune Pro, so it’s been harder than it should be to figure it all out. FM thinks it is a solid product and the PV supposedly works well with it.
When FM sent me the stock improved tune, I then ran an autotune session to fine tune it. I was just running autotune basic since I don’t have the enhanced product with the wideband O2 sensors. Then I loaded the result of that first smart tune session, and then ran a smart tune of that, further refining the result.
Rodc55
06-19-2019 08:43 AM
Bobcat264
07-28-2017 11:48 AM
