After tune higher idle
Old 11-11-2021, 05:56 PM
cj24's Avatar
cj24
cj24 is offline
Default After tune higher idle
Hey guys, got my power vision tuner from fuel moto. Uploaded the new tune ... pretty slick even a monkey could do it. Anyway, my idle after warm up is about 950-970 ... about 100 rpms higher than stock. Sound about right? Not sure what fuel moto sets the idle on their maps.
Old 11-11-2021, 06:02 PM
gonemad's Avatar
gonemad
gonemad is online now
Received 7,354 Likes on 2,961 Posts
Yes. Keeps that oil flowing better. My new tune is likewise.
Old 11-11-2021, 08:15 PM
cj24's Avatar
cj24
cj24 is offline
Alright sounds good. Thanks!
Old 11-15-2021, 04:05 AM
Gordon61's Avatar
Gordon61
Gordon61 is offline
Apparently the PowerVision will not set the idle below 950 rpm, no matter what number you put in there. Presume DJ think you need better oil flow too
Old 11-15-2021, 06:25 AM
Steve Sportster's Avatar
Steve Sportster
Steve Sportster is offline
Received 2,258 Likes on 1,096 Posts
I have an FP3 tuner installed on my 2018 Heritage. I decided to up the idle 100 rpm to increase oil flow and charge the battery a bit better.
Old 11-17-2021, 08:44 AM
Crispy's Avatar
Crispy
Crispy is offline
My M8 PV tune from FM is set to 980 rpm.
Old 11-17-2021, 10:57 AM
Wide06's Avatar
Wide06
Wide06 is offline
My PV allowed me to set 850.
My '18 was at 850 from the dealer, and the PV made it 950, so I set it back to 850 and contacted Fuel Moto because I also replaced my oil pump. They still recommended no less than 900 for oil pressure, regardless of upgrading the oil pump. They don't test oil pressure at lower idle (particularly with different pumps), so they only recommend >900.
I'll stick with >900 unless there's some verified testing of an oil pump that guarantees good pressure at rumpity-bumpity potato-potato idle speeds.
TomBe (11-19-2021)
Old 11-17-2021, 11:23 AM
strych9's Avatar
strych9
strych9 is offline
Received 9,890 Likes on 3,702 Posts
The right cam will sound plenty good at the recommended 950 RPM.
Wide06 (11-18-2021)
Old 11-18-2021, 11:08 AM
Wide06's Avatar
Wide06
Wide06 is offline
YES! Love my Wood 22X!
strych9 (11-18-2021)
Old 11-19-2021, 12:40 PM
Gordon61's Avatar
Gordon61
Gordon61 is offline
Aye, mine does too ...but that's not what it ends up idling at, have a look at your logs
Quick Reply: After tune higher idle
